FEROFORM slide pads give low friction, ease of movement and long life in equipment such as stacker trucks, container lifts and sliding booms. The high load carrying capability of FEROFORM bearings and slide pads is beneficial in agricultural equipment, earth moving and crushing machines, forestry machines & lifting equipment. The high abrasion resistance of TENMAT bearings gives long life in arduous applications, such as stone crushers and graders.
Wear problems are commonly found in many industries using heavy machinery for the movement and processing of abrasive materials. FEROBIDE prolongs the life of critical components by providing protection against high abrasion, heavy impacts and erosion found in material handling, ground engaging equipment and more. The superior toughness of FEROBIDE proves valuable in high-impact applications such as chutes, exhaust fans, ballast tamping, belt scrapers, impact plates, bucket wear pads and scarifying. Combining a high resistance to chipping with its superb wear properties, FEROBIDE continues to perform where other materials such as alumina and commercial tungsten carbide fail.
FEROBIDE comes in various thicknesses to suit “low profile” requirements, whilst leading edges remain sharp. The specialist FEROBIDE formulation means it outperforms standard materials under the demands of even the most aggressive of environments. FEROBIDE offers easy attachment through welding and is simply customised using regular workshop tools. This offers an unrivalled adaptability to large equipment manufacturers, local workshops and field repairers.
